We should add that the numbers inside the plot, on the left side (single pulse, 0.01, 0.02, etc.) are duty cycle (1%, 2%, etc.).It;s actually a plot of thermal IMPEDANCE versus pulse width (in time duration), which is to say pulse width of the power pulse which is creating the heat. Thermal impedance, or thermal resistance, is how much resistance there is in heat flowing from the die to the heat sink. It varies with pulse width because a very narrow puls just heats the local mass but as the width increases, it reaches steady state heat saturation of the mass and it is continuous flow of heat. For that reason, the aparrent thermal resistance is much lower to a very narrow power pulse than it is for a wider pulse or continuous pulse.
For this device, steady state saturation is reached when the pulse width gets longer than about 100 ms.
Okey..but at what power is the curve valid...cause earlier i used the thermal resistance to calculate the maximum power...now it seems like i calculate duty cycle ...is that at the maximum current and voltage...or under possible maximum power dissipation based on the thermal resistance and maximum junction temperature of the mosfet?It;s actually a plot of thermal IMPEDANCE versus pulse width (in time duration), which is to say pulse width of the power pulse which is creating the heat. Thermal impedance, or thermal resistance, is how much resistance there is in heat flowing from the die to the heat sink. It varies with pulse width because a very narrow puls just heats the local mass but as the width increases, it reaches steady state heat saturation of the mass and it is continuous flow of heat. For that reason, the aparrent thermal resistance is much lower to a very narrow power pulse than it is for a wider pulse or continuous pulse.
Is tp the total time period on the graph...We should add that the numbers inside the plot, on the left side (single pulse, 0.01, 0.02, etc.) are duty cycle (1%, 2%, etc.).
Not sure how to explain. A good way to look at it is the thermal resistance is a specific value (on the data sheet) like for a T0-220 it would be typically about 3C/Watt for CONTINUOUS POWER.Okey..but at what power is the curve valid...cause earlier i used the thermal resistance to calculate the maximum power...now it seems like i calculate duty cycle ...is that at the maximum current and voltage...or under possible maximum power dissipation based on the thermal resistance and maximum junction temperature of the mosfet?
hope to hear form you soon...
III. Transient Thermal Impedance
The transient thermal impedance is a measure of how the device behaves when pulsed
power is applied to it. This is important for determining the behavior of low duty cycle,
low frequency pulsed loads. A typical transient thermal impedance curve from the
datasheet is shown in figure 3.
As one might expect, for low values of pulse width, the junction temperature is smaller
because the thermal capacity of the die, package and FR4 fixture board impose various
time constants on the rate at which junction temperature can rise.
by Jeff Child
by Jake Hertz
by Duane Benson
by Jake Hertz
