Hello Everyone...
I decide to make automatic cradle for baby's, for that i use magnet attraction and repulsion property. for that i attech 2 powerful magnet on movable pipe of cradle and put one coil near this magnet.
Now to obtain movement we need to energy's coil such a way that moment of cradle can be obtain.
for that i directly connect two terminal of coil with 12V DC power supply and make switching with hand. Current Rating was 2.5A when turn on. This way i obtain movement in one direction. as i increase coil voltage large movement can be obtain.
after that i decide to switching it with micro-controller so i can obtain movement in both direction by changing current flow direction. for that i use H-BRIDGE concept.
i make h-bridge using Relay but it make noise as TICK TACK.
To Avoid this problem i use power mosfet 55NF06.
Circuit diagram is attached with this post...
http://forum.allaboutcircuits.com/attachment.php?attachmentid=64855&stc=1&d=1392442897
Problem with mosfet is, after starting circuit mosfet start heating and after minute it become fry.
please help me, what should i do to avoid this kind of problem....?
Thank you..!!
Bhargav Shankhalpara India.
Thank you..!!
