Data sheet time.
http://www.mouser.com/ds/2/389/DM00095160-490569.pdf
Page 1 top right. Rds .165 ohms. This is the resistance of the FET when it is turned on hard and it's temperature is 25C. As a matter of note almost all the specs are at 25C.
Table 3 shows the temperature rise per watt in the FET. So with no heat sink it's temperature will rise 50C per watt.
You have 8 watts - 7^2 X .165 ohms. So it would go to 425C (if it could)
Then if you look at Fig. 11 it shows what happens to Rds on with temperature. Over 2 X higher at 150C. So suddenly the resistance is .33ohms. So now you drop 2.3 volts across the FET instead of 1.15. At 450C things are melting.
You could use one like this:
http://www.mouser.com/ds/2/200/irfp4110pbf-82436.pdfThen Rds on is only .0045 ohms - .22 watts.
