Mosfet Smoking within operating limits
urb-nurd
Joined Jul 9, 2014
269
wayneh
Joined Sep 9, 2010
17,498
You're using an N-channel as a high side switch. Move it to the low side, source to ground. When you reverse it, you send current through the body diode no matter the state of the gate.
urb-nurd
Joined Jul 9, 2014
269
I see - so source to ground and drain to Vcc?
This stops latch up - but i still get smoking when i drive the gate at 10V
urb-nurd
Joined Jul 9, 2014
269
This awful paint rendition shows what's going on.
Also - the 25 pulsed dc produces around 34V peak to which the cap charges.
This dc level is maintained at the top of the v divider for driving the gate.
ScottWang
Joined Aug 23, 2012
7,398
Maybe you should cut off the wire from the common of 4.7K and 2.2K to G of mosfet, you just connecting the wire from the common of 4.7K and 2.2K to the optocouple, and the pwm signal connecting to the G of mosfet.
There is a question here is that if the vg must >= 10V, then the pwm input also need to increasing the voltage up 10V.
The current from 4.7K and 2.2K maybe too less for the optocouple, you need to reducing the values of resistor.
RamaD
Joined Dec 4, 2009
328
The opto needs a good amount of current for the input diode, to make the output transistor conduct and goto saturation. What is the opto used and how much is the current to the diode? Schematics again!
urb-nurd
Joined Jul 9, 2014
269
The input for the opto is configured correctly. I have already used this configuration to PWM the gate of a IGBT with success.
But how much input current does that require?
As in how much is dropped across the opto output? I am not sure.
However - i havent got to the point of using the PWM to control the gate as i cant manage to get it working with 10V straight up.
urb-nurd
Joined Jul 9, 2014
269
Your first point relates to passing the gate voltage with the optocoupler rather than sinking it? I did try this but the datasheet shows it being sunk as an example.
The aim of the PWM is to drive the gate to 10V and then to zero rapidly - rather than to average out a voltage over a time period.
I think you may be on to something with the gate current !
ScottWang
Joined Aug 23, 2012
7,398
I attached the circuit as below, you can check where should to modify.
urb-nurd
Joined Jul 9, 2014
269
First - let me clarify i can understand the circuit - given that it is more than a slight alteration.
The zener and R1 provide a 12V voltage for the gate - with the capacitor in parallel holding that level.
R2 limits the current into the opto.
The PWM output of my microcontroller will short the input to the opto to ground when high via a transistor Q1.
The 12V gate voltage is passed by the opto when the PWM output is low.
22k Gate resistor to stop ringing.
Now i am afraid i have a few questions...
Why the zener rather than a Vdivider? (i also do not have any zener diodes)
Why is the additional transistor necessary? The optocoupler i am using (4n25) seems to operate just fine with my 5V output from my microcontroller - and worked in this manner for my high voltage bulb testing.
I am still struggling to get my mosfets to conduct reliably with a straight 12V applied to the gate - i am not at the point of using the opto and PWM for rapid switching.
urb-nurd
Joined Jul 9, 2014
269
This is what i am using at the moment.
I am simply trying to get the 10+V at the gate to switch the mosfet so that pulsed DC can flow through the bulb.
EDIT: fixed an issue - with no gate voltage - the mosfet smoked and the bulb was very dim.
I added a 700K resistor from the gate to ground and now it works as expected when applying the gate voltage and removing it!
Now to try and PWM through the opto!
If anyone has an idea of what is going on without that gate resistor to ground - im intrigued to find out.
urb-nurd
Joined Jul 9, 2014
269
One issue sorted - the optocoupler does not vary from zero to full.
When the PWM output is at 100% (shorting the gate to ground, therefore should be zero V) i can see that it is only managing to drop to half its max before rising again.
This has to do with the PWM frequency and the optocoupler maybe.
ScottWang
Joined Aug 23, 2012
7,398
If you like then you can still using the resistor.
I just drawn the normal driver circuit, If you want then you could take the bjt away, and using the port of uC to drive the LED.
