I am working on creating a battery pack management system for some lithium polymer batteries. for the project i have selected the texas instrument BQ77PL900 chip.
chip data sheet.http://www.ti.com/lit/ds/slus844b/slus844b.pdf
battery data sheet. http://www.batteryspace.com/prod-specs/5072.pdf
the battery pack will consist of seven cells in series. each cell is 3.7 volt nominal, 10Ah and can provide 80A continuous. the pack will be used to run an amp flow motor that is capable of consuming 150A.
to protect the pack the TI chip uses two very large p-type mosfets. if an overcurrent condition is detected either during charging or discharging the chip shuts down the pack by blocking the current flow with the said mosfets. selecting the current rating for the mosfets is easy. as long as it exceeds 80A and i properly select a heat sink then everything is fine.
my question is how to select the proper voltage rating for the mosfets?
the pack should never exceed 4.2 volts a cell so as a whole the seven cells should never exceed 29.4 volts.
would a 30 volt mosfet be plenty or do i need to provision a safety margin for instance 60 volts?
is there any disadvantage in using a mosfet that has double the working voltage?
