Mosfet replacement help needed.
Discussion in 'The Projects Forum' started by ant247, Mar 2, 2014.
  1. ant247
    Mar 2, 2014
    10
    Hi all,
    I just joined this site as I am in need of a little help.
    I am quite new to electronics, and just completed the picprojects 5x5x5 LED cube.
    I have done a search on the forum but haven't got any results for my latest problem.
    I suppose some of you have seen the LED Cylindar on the web,
    http://www.nycresistor.com/2008/07/26/led-cylinder/
    well, I want one.
    I have just about a full parts list now but I am having trouble with the Mosfets.
    The cylindar uses 5x IRLU3715's, which are no longer available, and no alternative is listed for it.
    The IRLU works with a TC4427a to drive it.
    Can someone assist me in finding an alternative for this mosfet please, this is the last part I am having trouble with.
    Thanks in advance for all your help and advice, everything is greatfuly recieved.
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    If you go onto the Radio Spares webpage for this device here it suggests a number of similar products via the tab. The top one looks to be a good alternative, it just a case of comparing the specifications and finding one that's matches the IRLU3715, the STI45N10F7 looks OK.
  3. ant247
    Mar 2, 2014
    10
    Thanks for that Paul, I will certainly look into these.
