MOSFET question
Discussion in 'General Electronics Chat' started by bug13, Mar 14, 2013.
  1. bug13
    Feb 13, 2012
    1,214
    38
    Hi guys
    Is there a mosfet that can block current flowing from S to D when in its turn off state?? or is there other way to doing this if I don't want to use an diode in series.
    The Imax(on) is about 5-6A, the voltage need to be blocked is about 35V when the mosfet is off.
  2. t_n_k
    Mar 6, 2009
    5,448
    783
  3. antonv
    Member
    Nov 27, 2012
    149
    27
    Conventional current flow or electron flow?
  4. crutschow
    Mar 14, 2008
    13,515
    3,386
    What are you trying to control?
    Two MOSFETS connected source-to-source in series may do what you want.
