In looking at schematics using a MOSFET as a switch, I have noticed that BOTH the signal and load voltages use the same ground. What do I do if my signal source voltage and my load source voltage are from two entirely different circuits? For example, what if I wanted to use a battery for my 5v signal source and I wanted the MOSFET to switch on a 24 volt bulb? Thank you.
