MOSFET problem
Discussion in 'Homework Help' started by chintu84, Nov 15, 2006.
  1. chintu84
    Oct 18, 2006
    6
    Parameters: VTn = 0.75, Kn = 25 uA/V2, lambda = 0.05 V-1, Vdd = 10 V.
    Calculate the output impedance (the total impedance as seen from the node labeled Vo) of this circuit, if IDS is 1.2 mA.
    Express your answer in Ohm, accurate to 1 Ohm.
    I have attached the circiut for this problem and i have been tring to solve this problem for 4days, and i hav got the answer as 2/gm, but the answer was wrong when i substituted the values.
    can any one help me to solve this problem.
    i have tried using small signal analysis.
  2. n9352527
    Oct 14, 2005
    1,198
    Could you post your attempt in steps please?
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Posting your attempts at the small signal analysis would help. I take it you have modelled M2 as a resistor in the small signal model?
    Dave
  4. chintu84
    Oct 18, 2006
    6
    i got the out put impedance to be
    Ro=Rs+ro(1+(gms+gmbs)Rs)
    Rs=Vs/Ids
    ro=1/lambda*gms*vs
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Sorry to be picky, but can you post the small-signal model circuit that you performed the above analysis on? The suitability of your equations is dependant on the circuit you perform the analysis on.
    Dave
