I would be very reluctant to make that assumption. There is usually a max current that should not be exceeded regardless of the briefness of its duration.Hi guys,
For example, the datasheet of a MOSFET states that its peak pulsed current is 50 Amps for 1us.
Is it possible to have a peak pulsed current of 100 Amps for 0.5us or the MOSFET will be destroyed?
Does that mean one might model the pulse 'rating' behaviour somewhat like a fuse "let-through" energy parameter -Download the datasheet and look for an SOA (Safe Operating Area) graph. It will tell you the absolute maximum current and different pulsed maximum current. Do not make an assumption, because the maximum current is not related to only thermal condition of the die, but also the bonding wire used.
