MOSFET P Channel
Discussion in 'General Electronics Chat' started by BULL04, May 21, 2014.
  1. BULL04
    Jun 16, 2010
    7
    Hello
    I am looking for P channel MOSFET,100-150mA.
    I want to use it as a switch (attached a picture):
    Gate - from Microcontroller(3.3V)
    Sourese- 3.3V power_in
    Dreain - 3.3V power out.
    Please recommended to me about part number to use ( package = sot 23 )
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
  3. BULL04
    Jun 16, 2010
    7
    Ok,
    The Continuous Drain Currentis 2.2A, I am looking for Continuous Drain Current=150mA.
    I am using this switch to supply a power to RS485 part.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    But what wrong is with 2.2A ?
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    the maximum power is no problem as long as its higher than what is necessary, the circuit will not get more power from a higher rated mosfet, the current is dertermined by the load.
  6. BULL04
    Jun 16, 2010
    7
  7. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes you can can use it.
    Also don't forget to add pull-up resistor between source and gate.
  8. BULL04
    Jun 16, 2010
    7
    Do you mean to put resistor 4.7K between source and gate?
  9. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yep, and 10K also do the job.
