Mosfet not turning off
Status
Not open for further replies.
soderdaen
Joined Nov 21, 2015
16
Hey guys,
I am working on a project which is a load controller for a water turbine in stand-alone operation.
When the regular load is to low or the river is to fast, there is a power surplus which has to be dissipated. That's where the lamp comes in.
The microcontroller realizes that too much power is available and gives a signal to the mosfet to switch on. The power supply is realized by a capacitive power supply.
The problem is following: When I give a high signal (5V) to the Mosfet and it turns on the way it should. But if the signal is low (0V) the mosfet does not turn off. Instead the lamp is shining less bright. Even if put out the cable from the µC to the mosfet and hold it to the source/ground the light doesn't turn off.
When I put the grounds of the mosfet (at source and the ground at the 1k resistor) to a separate "ground 2" the mosfet shows the same behaviour BUT now I can remove the signal from the µC and the lamp is totally off.
The mosfet is working properly by the way. When test it all alone with a different ground it is working.
I think it has something to do with the grounds but when I measure the signal based on the ground with a differential probe on the oscilloscope, then there is the right signal at the mosfet.
My question is: Why does the mosfet behave like this and how can I make it work properly?
Sorry for my grammar, I am from germany :p
Alec_t
Joined Sep 17, 2013
14,280
Try connecting R8 (1k, but could be higher) directly between the gate and source of the FET. Ideally you should have a single-point ground so that high current via the FET drain and source doesn't cause 'ground bounce' which would change the Vgs voltage.
ian field
Joined Oct 27, 2012
6,536
Hey guys,
Did you actually verify by measurement that Vgs is going sufficiently below Vgs-thr?
If you picked a MOSFET with very low RDSon, it'll conduct a fair bit until you get Vgs well down on VGSthr.
wayneh
Joined Sep 9, 2010
17,496
"Ground" is not always ground if current is flowing. Check to be sure you have good wiring that can carry the currents involved.
Dodgydave
Joined Jun 22, 2012
11,284
Replace the fet with a Thyristor, that will switch off automatically as the voltage goes to zero.
NOTE, TRANSFORMERLESS PSUS ARE DANGEROUS.
beachten Sie , transformatorlosen Netzteilen sind gefährlich !
Status
