Mosfet N-Channel IRFZ40 Not turning off -HELP
Discussion in 'General Electronics Chat' started by rockrazz, Dec 31, 2014.
  1. rockrazz
    Dec 31, 2014
    I've looked all over and remember something about adding a resistor somewhere
    to drain the mosfet so it shuts off.
    Right now i have 3.5v going to the gate. It turns on when 3.5v is applied, but not turning off when the 3.5v drops. The Red LED just remains lit.
    Any help would be highly Help.jpg appreciated
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Add a 10K to 100K resistor from Gate to Source.
    Add a resistor in series with the LED, else you will blow it up (unless it is a 12V indicator lamp assembly with an internal resistor).
    According to the IRFZ40 data sheet, 3.5V is marginal to turn on this NFET. It will work for a light load, but not for a load that draws more than a 100mA.
  3. rockrazz
    Dec 31, 2014
    Thank You,
    I have a 4pk new package of NTE 1/4W 560 OHM 2% resistors. Would those work?
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Yes. The only downside is how much current you will have source from whatever drives the Gate?
  5. ian field
    Distinguished Member
    Oct 27, 2012
    4,464
    792
    Short circuit gate to source - if the MOSFET doesn't turn off, its toast. (You have got it right way round for the channel polarity haven't you?!).
    If the MOSFET with G/S shorted turns off, replace the short with a resistor, anout 2k2 - 10k should do.
    The MOSFET gate has capacitance - if it doesn't have a bleed resistor, you can put a static charge on the gate that will keep the MOSFET conducting for hours.
  6. cmartinez
    Jan 17, 2007
    3,700
    2,802
    I suggest you watch these tutorials, they explain quite clearly how mosfets work in real applications
    spark8217 likes this.
