mosfet mayhem the sequel
Discussion in 'The Projects Forum' started by ingram010, May 2, 2007.
  1. ingram010
    May 2, 2007
    6
    I am trying to switch 500vdc supply, I am using (Transistor,MOSFET,N Channel,SPP02N60S5) supplied buy RS.
    Problem - the 500v supply is on wether or not the gate has a supply.
    Attached is a sketchy schematic.
    Please, please can someone help?
    Many Thanks
    John
  2. nomurphy
    Aug 8, 2005
    567
    12
    The power supplies must have the same common, see attached:
  3. John Luciani
    Apr 3, 2007
    477
    Besides connecting the grounds together (as previously mentioned) you really should
    have a zener diode across the gate and source of the MOSFET (probably a cap too)
    to suppress switching transients.
    (* jcl *)
  4. ingram010
    May 2, 2007
    6
    thankyou for your help
    John
