I am using a SI1488DH-T1-E3CT-ND mosfet and I am controlling it through a micro controller. The switch speed is pretty fast (about 6 us on, then it turns off for 50 us). The issue is that my PS gets lots of ringing (a decaying oscillation) now when the circuit goes. I was able to get the ringing down by adding a .1 uF ceramic cap to ground, but the ringing is still there (initially about 300mV, then it decays...it was originally a 1V initial peak!). What can I do to get rid of this ringing?
Also, for the FET, the Vgth is very low, but I still cannot get a lot current from drain to source. Basically, I need the LED (LE UW S2W) to be as bright as possible, but it looks like I am getting the same voltage drop at the drain no matter what current sourcing resistor I use. It seems like it is really half as bright as it should be.
