MOSFET/JFET tutorial for dummies
Discussion in 'Electronics Resources' started by Skfir, Dec 23, 2010.
  1. Skfir
    Thread Starter Active Member
    Aug 19, 2010
    135
    Hey pipz, since the chapters on MOSFET/JFET transistors are not ready yet, might anybody advise me any tutorial on the matter to read meanwhile?
    Thanks dudes!
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Are you wanting concepts or the full mathematical treatment?
    Dave
  3. Skfir
    Aug 19, 2010
    135
    probably both, if possible please.
  4. ELECTRONERD
    May 26, 2009
    1,146
    16
    Skfir likes this.
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Skfir likes this.
  6. Skfir
    Aug 19, 2010
    135
    Thanks guyz!
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    If you can get access to a copy, Chapter 4 in Sedra and Smith is an excellent treatise of MOSFETs - the best conceptual and mathematical approach to the MOSFET I have seen.
    I don't necessarily recommend buying the book as it is expensive, but if you can get hold of a copy from a library I suggest you do.
    Dave
    Skfir likes this.
  8. Skfir
    Aug 19, 2010
    135
    Surprisingly, I could get hold ;) Thank you really a lot!
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    Lucky guy! It's out of print, unfortunately.
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I can't quite put my finger on this. If you have a look on Amazon there is an edition available here. It says it is the 5th edition, which is the same as my copy. However, having browsed the table of contents there appears to be a difference between the sub-topics covered. It says that is the "International Students Edition" so I wonder if there is some differences between that and my edition.
    Unfortunately, from my perusing of the TOC it appears the edition on Amazon doesn't cover the MOSFET to extent my copy does.
    I will do a little more digging as Sedra and Smith is regularly recommended here on AAC and I would like my information to be current. If you find anything please feel free to post up. Thanks.
    Dave
  11. Skfir
    Aug 19, 2010
    135
    Well... mmm... I wouldn't say that my 'copy' is very hard... if you got what I mean... I would be happy to... mmm.... share some knowledge amongst us but not sure direct links are approved here.
  12. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Yes we won't be saying anything more on that ;)
    If Chapter 4 is MOSFETs then you have the same version as I, and I recommend you read that chapter. If, however, Chapter 4 is BJTs then you have the International Edition and MOSFET are covered, in less detail, in Chapter 5 under the section titled FETs alongside a brief introduction to JFETs.
    Dave
