Hello all,
I haven't looked at MOSFET's in a long time, and I'm a bit rusty. I wanted to make sure that I can "turn on" the MOSFET.
I am looking at a IXFA8N50P3 - http://ixapps.ixys.com/DataSheet/DS100455A(IXFA-FP8N50P3).pdf. From my quick review (reading the spec sheet, checking AAC references, and Google searching) I know that Vgs is the MOSFET turn on voltage and the for the MOSFET to turn on, Vgs>Vth.
The spec sheet stated Vgs(th) to be 3-5V. From what I've gathered, the Vgs(th) is the voltage required to turn on the MOSFET. I am a bit confused by this and I have 2 interpretations.
1) a Vgs between 3-5V will turn on the MOSFET.
2) Vgs must be greater than 5V, since that is the minimum voltage required to turn on the MOSFET.
Can someone point me in the right direction?
Thanks,
Matt
Thanks,
Matt
