MOSFET IS BECOMING HOT WITHOUT LOAD
Discussion in 'The Projects Forum' started by ADI89, Sep 22, 2015.
  1. ADI89
    Aug 13, 2013
    10
    HI,
    I have designed a full bridge DC DC converter by using Mosfet as switch. Mosfet Part no. stw22n95k5.All the four mosfet are mounted on one heat sink with proper isolation.
    The switching frequency is 120Khz and DC input is 400V - 600 V.
    I have used pulse transformer after the gate driver IC for driving both TOP and Bottom Mosfet.
    Gate driver IC : ucc27324D
    Pulse Transformer : GT03 111 069B
    Gate resistance : 1 ohm to 47 ohm ( I have tried with different resistance)
    Gate to source resitstance : 10 K
    The heat sink is heating up even In no load condition also. After that I disconnected every thing and I gave the control supply to all four mosfet and incresed the DC input , still the heat sink is heating up.
    I am not getting the problem for this . Please help me in this matter.
  2. #12
    Nov 30, 2010
    16,704
    7,351
    Based on your word description, it should work. That's why we need a schematic of your circuit.
  3. ADI89
    Aug 13, 2013
    10
    Now I am not using isolated feed back , directly i am giving the feedback to the controller from the secondary side. I have removed the CT from primary side and shorted. There is one capacitor in series with resistor connected from gate to source. Now that also i have removed. These are the changes i have done .
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    You have to re-upload a clear circuit and cut the other useless space.
  5. ADI89
    Aug 13, 2013
    10
    Another thing i forgot to mention that, when i am increasing the input DC voltage mosfet is getting more heat. untitled.JPG
  6. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Have you checked the Vgs waveforms on a scope to ensure you're getting clean abrupt switching of the FETs?
    Roderick Young likes this.
  7. kubeek
    Sep 20, 2005
    4,689
    806
    Are you sure you have enough dead time?
  8. dannyf
    Sep 13, 2015
    2,196
    417
    Switches don't dissipate much power if they are fully turned on / off. However, under light load, the incoming pulse may be too short to fully turn them on. The solution is to limit duty cycle or to use a beefier driver.
    Similar things happened to a then "famed" and now forgotten Class D amplifier designer in the 1990s until I pointed that out to him - his amplifiers would work fine under heavy load but quickly burn up under no / light load.
  9. Sensacell
    Jun 19, 2012
    1,183
    276
    What is the bridge connected to?
    Are there reactive currents flowing in some type of output filter?
    Can you post more of the schematic?
  10. ScottWang
    Aug 23, 2012
    4,933
    777
    Some reasons may cause heat as:
    1. High frequency oscillation.
    2. Deadtime between up side mosfet and low side mosfet.
    3. The rating wattage of mosfet is not enough.
    4. Heatsink is too small.
    If you have O'scope then you can measure the input/output waveform of mosfets bridge.
  11. ADI89
    Aug 13, 2013
    10
    Waveform 0039 :The yellow one is drain to source voltage of one mosfet and blue one is transformer primary current.
    Waveform 0012 : The yellow one is gate to source voltage and blue one is drain to source voltage of same mosfet.
    Both the waveforms are for same mosfet.
  12. RamaD
    Dec 4, 2009
    254
    33
    How much is the primary current? As the waveform shows the voltage.
    The magnetizing current could be high.
  13. ScottWang
    Aug 23, 2012
    4,933
    777
    Did you compare the deadtime between up side mosfet and low side mosfet?
    If the upper mosfet and lower mosfet turn on at the same time or very closely then the mosfet will heating up without load, during that time two mosfets will flow through a great current ad they will become two loads.
  14. ADI89
    Aug 13, 2013
    10
    Primary current (Amp) = Waveform Voltage / 6
  15. ADI89
    Aug 13, 2013
    10
    I have given sufficient dead time. I have attached the waveforms (gate to source voltage) of both top and bottom Mosfet of same leg.
    Zero Voltage time is the deadtime.
  16. ADI89
    Aug 13, 2013
    10
    Drain to source voltage pattern are coming different in different leg. The wave forms are given below.
    Blue one : Drain to source voltage
    Yellow : Gate to source Voltage
    Actually the converter is a phase shifted Full bridge converter.
    Is this reason for this difference in drain to source voltage waveform?
  17. ADI89
    Aug 13, 2013
    10
    Gate to source voltage of both top and bottom device
  18. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Those waveforms clearly show overlap of the pulse edges, i.e. apparently no dead-time. The upper and lower FET Vgs should have dead-time like this :-
  19. kubeek
    Sep 20, 2005
    4,689
    806
    Alec, I think you are looking at it wrong, you can see that there is a significant time where both gates are at 0V, and then one goes to +15V and the other to -15V i.e. one transistor goest on and the other stays off.
  20. Alec_t
    Sep 17, 2013
    5,976
    1,136
    Oops. Quite right. I assumed the two waveforms were being shown with a relative DC shift for clarity.
