MOSFET inverter power calculation
Discussion in 'Homework Help' started by smrams28, Apr 14, 2013.
  1. smrams28
    Mar 29, 2013
    13
    Hi. I was working on this problem and could use some help. I have to calculate the power dissipated. My thinking was to find the drain current and then multiply it by the drain voltage to get power but thats not right.
    WHAT I DID:
    Vdd-Vd = V = 5 - 0.9 = 4.1 V
    V/R = I = 4.1V/1.6E3 = .00256 A (drain current)
    P = I^2R = (.00256)^2*1.6E3 = .0105 W
    The inverter circuit above consists of MOSFET and the load resistor, R = 1.6 kOhm. The inverter bias voltage is Vdd = 5 V; the MOSFET threshold voltage is 0.5 V. The gate input voltage is +5V. Under these conditions, the MOSFET drain voltage is Vd = 0.9 V; Assuming that the MOSFET I-Vs are linear at this drain voltage, find the power (in Watts) dissipated in the inverter circuit.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes you right. The power dissipated in the MOSFET is equal to voltage across the MOSFET (drain to source voltage) multiply it by drain current.
    But here you calculate power wasted in the resistor not in the MOSFET.
    After all, you wrote
    "drain current and then multiply it by the drain voltage to get power."
    And next you don't follow your own words, and calculate the resistor power. Very strange.
