Mosfet High Current !!!
Discussion in 'General Electronics Chat' started by banzai, Nov 9, 2014.
  1. banzai
    Jan 3, 2014
    71
  2. Robin Mitchell
    Oct 25, 2009
    738
    206
    Im not too sure what you mean but it sounds like what you are asking is "Why can a MOSFET conduct that much in theory but not in practice?". The answer is that if you can keep the MOSFET cold enough then it will be able to conduct that much without exploding, melting or vaporizing. Also, you have two types of current, instantaneous and continuous. For a brief unit of time (like 1ms), a transistor could easily conduct up to 100A but continuously (over a long period of time), it can only conduct 100mA due to heating.
  3. Robin Mitchell
    Oct 25, 2009
    738
    206
    Also that transistor can dissipate 330W (with a damn good heat sink), so if you use P=I^2 R the R is 4.7m Ohms and I is 100A so the total power dissipated is 47W.
  4. banzai
    Jan 3, 2014
    71
    Well 175 Amps is not a small load, i don't get the picture here, if you can keep it cold at that temperature it reaches when conducting 175 A, why cant you make it conduct even more current. This sounds like super conductor stuff.
  5. Robin Mitchell
    Oct 25, 2009
    738
    206
    Current is dependent on voltage and resistance. If you make the device really cold then yes it should be able to conduct that much. But then again, some device can only operate within a range of temperatures so it can only be made so cold. Plus there are factors such as reverse voltage breakdown so when you try to reach those currents you might break down the depletion zone between the body and the source/drain.
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
  7. ScottWang
    Aug 23, 2012
    4,929
    777
    Where is the schematic?
    What is the load? (Motor, Solenoid valve...)
