praondevou
- Joined Jul 9, 2011
- 2,942
How the reset occurs you will have to measure.
I was asking for the layout to know if there is a gnd wire directly from the ATm board to the driver board or if the ground is routed only through the black wires seen in the foto.
I would connect a power supply to the IR2110. The from there I would run a power supply to the Atmega. The ground wire of theis power supply will also serve as the return path for the PWM signal from Atmega to driver.
Is it connected like I described?
