I have attached a schematic picture to help understand this project. I simply do not understand what's going on and was hoping for people with bigger brains than myself to answer this.
Here is what this project does in short - it has a sound detector so when I knock on my desk, the 1st led lights for as long as the sound is detected, then it cycles to the next led, rinse and repeat infinitely. When it gets to RC5 of the chip, there is a 3v dc - ac power supply that puts out about 200vAC. I simply hooked a light to it - (very low amperage). Here is the problem:
If I hook an led up to this fet, it works fine
If I hook up the 3v dc - ac inverter on BATTERIES, it works fine (essentially I am switching the batteries on and off)
If I hook up the inverter as in the schematic (trying to not user batteries and use the main power instead) it gets stuck on.
*There is a resister not shown in the schematic to lower the voltage from 5v to 3v when trying to use the inline power
What do I mean by stuck on? It's almost like some kind of loop - the sound detector acts as if someone stuck a voltage across it somehow to cause it to trigger, thus the gate triggers.
For the LOVE OF GOD what am I doing wrong?
