MOSFET gate
Discussion in 'Homework Help' started by vustudent, Oct 11, 2009.
  1. vustudent
    Thread Starter Active Member
    Mar 11, 2009
    38
    What do you mean by a high K gate dielectric?
  2. steinar96
    Apr 18, 2009
    239
    There is usually a insulating material (usually silocon dioxide between the gate and the substrate) of a mosfet transistor. Being high K means it has a high dielectric constant if i remember correctly.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    Perhaps the attached PDF will give some more info.
    Greetings,
    Bertus
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    In a roundabout way, yes.
    k is the process trandconductance parameter of dimensions A/V^2. It is the product of the surface mobility of electrons in the MOSFET channel which is a function of the doping processes, and the capacitance of the gate oxide-layer which is defined as the dielectric constant of the oxide layer over its thickness.
    Dave
