MOSFET gate resistor value
Discussion in 'General Electronics Chat' started by lokeycmos, Jan 4, 2013.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    quick question, i am substituting IRFP460 MOSFETS for this inverter circuit:
    http://electroschematics.com/220/12v-dc-220v-ac-converter/
    could someone please show me how to calculate the ideal gate resistor for this application? i know that the gates are voltage driven, so do i even need resistors? please show me how you calculate so i can learn. One other thing, i know i can put MOSFETS in parallel to increase the current handling. Does this affect the value of the gate drive resistor? thank you!!
    datasheet is here:
    http://www.vishay.com/docs/91237/91237.pdf
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
  3. lokeycmos
    Apr 3, 2009
    432
    7
    ok thanks. a little more help is needed. the total rise and fall time is 117nS. so i multiply that by 5 and i get 585. the input capacitance is 4200pF. with this what formula do i use to get resistance in ohms?
  4. tracecom
    Apr 16, 2010
    3,879
    1,396
    I didn't mean to imply that I knew the answer. I am hoping someone else will explain it to both of us. :)
  5. lokeycmos
    Apr 3, 2009
    432
    7
    so if i have 2 mosfets in parallel the gate capacitance would double. then i just use the same formula that i hope someone will post?
  6. lokeycmos
    Apr 3, 2009
    432
    7
    let me know if i got this right.
    charge time = 5*R*C
    117nS = 5*R*4200pF
    117nS=R*21000pF
    R=.000000117/.000000021= 5.57 ohms
    please verify this for me and correct any mistakes. TY
  7. lokeycmos
    Apr 3, 2009
    432
    7
    anybody? Thank You!
  8. lokeycmos
    Apr 3, 2009
    432
    7
    could anyone verify post #6 for me? im basing these caculations from information in the link in post number 2
  9. GopherT
    Nov 23, 2012
    6,339
    4,084
    That would be the maxium resistance you could use. Since virtually no current flows through the gate once the gate capacitance is charged, you don't need to limit the current flow like in a bipolar transistor.
    Your intuition was correct in your first post, you really don't need the gate resistors unless you are possibly pulling the gate voltage ABOVE the Drain voltage. note that those are general recommendations, I have not idea if your simple replacement will still work int his circuit.
  10. vrainom
    Member
    Sep 8, 2011
    109
    19
    The gate driving resistor is only critical in very high frequency circuits, where Rgate * Cgate becomes a significant part of the period in the operation frequency. For tens of kilohertz I think it's quite common to use a Rgate of anywhere between 10 and 47 ohms.
