mosfet gate oscillation problem
Discussion in 'The Projects Forum' started by mobydick, Mar 19, 2012.
  1. mobydick
    Nov 19, 2010
    27
    hello
    i am trying to build half bridg using p and n mosfets
    when p type mosfet turn on oscillation appeare at the gate
    and when i disconnect drains of the p and n mosfet it disappears
    any help pleas
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The gate-source of a Mosfet is a capacitor. The wire feeding the gate is a series inductor. The capacitance and inductance oscillate or ring.
    That is why most Mosfets have a low value resistor (10 ohms to 100 ohms) at the gate pin in series with it to kill the inductance.
  3. mobydick
    Nov 19, 2010
    27
    but there is 500ohms resistor on the gate during the on time
    Mayank Amipara likes this.
  4. kubeek
    Sep 20, 2005
    4,686
    805
    but that is reistance in parallel, not in series with the gate.
  5. Ron H
    Apr 14, 2005
    7,050
    657
    Do you have power supply decoupling caps on +30V?
    Do you have a load on the drains that is not shown?
    mobydick likes this.
  6. mobydick
    Nov 19, 2010
    27
    during off time resistor is in parallel , but i have no problem at off time of the p mosfet
    at on time of the p mosfet the resistor is in series (right !!)
    no i didnot
    after adding 470 n oscillatin decreased (new screen shot attached ,note NG ch1 is 1v/div while PG ch2 is 5 v/div)
    no i donot . will that make diffrance?
  7. Ron H
    Apr 14, 2005
    7,050
    657
    It will probably make a difference. Why don't you try it?
  8. mobydick
    Nov 19, 2010
    27
    when i put 50 ohms from drain to GND no change
    and when i put 50 ohms from drain to +30 it changes( picture attached)
    what is the reason for that oscillation?
  9. Ron H
    Apr 14, 2005
    7,050
    657
    Can you show us a picture of your hardware, i.e. breadboard or PC board?
  10. mobydick
    Nov 19, 2010
    27
    hello all
    sorry for late respond (exams :mad:)
    any way , i did some simulations and put random inductors every where . i found the exact same noise happens when i put an inductor between source of the mosfet and ground . bad nois also from source to vcc inductor .
    so i redesigned the circut with huge vcc and ground tracks and problem disappeared :)
    thanks
