mosfet failure 150watt inverter
charanbandi
Joined May 17, 2012
18
I am working on inverter 150w using pwm Ic3524 to switch IRFZ44 mosfets.I am not getting the output.
I have tested mosfet individually by connecting it to a battery i.e across drain and source using a 200ohm resistor without giving any gate signal i.e leaving the gate terminal and i am getting about 1amp current flowing across the source and battery negative terminal i.e Id is 1amp.
But according to the datasheet of mosfet zero gate voltage drain current is 10µA max.
Why i am getting like this??If that is the failure of that mosfet i have tested 8 mosfets and all are showing the same current??
Is there something wrong with my testing??
Thank you ..
SgtWookie
Joined Jul 17, 2007
22,230
You should have the gate connected to the source terminal to ensure that Vgs=0v.
If Vgs exceeds ±20v, even for an instant, the MOSFET will be destroyed.
I don't know why you are using a CA3524, as it's designed to drive BJT's (transistors) instead of MOSFETs. The 22k resistors are the path for discharging the gates when it's time for the MOSFETs to turn off, and that will take a fair amount of time. During that time, the MOSFETs will be in partial conducting (resistive) mode, causing rapid heating. This could be the cause of MOSFET failures.
charanbandi
Joined May 17, 2012
18
even if i havent connected the gate to the source.i shouldnt be getting any current (Id) why i am getting 0.8 to 1 amp??
and
how to test a mosfet whether it is working or not??!!
34,451
and
Not true. The gate looks like a capacitor and, if it is left floating, then it can be at any voltage due to stray charges which will cause it to conduct current.
To test a MOSFET you can apply a few volts to the drain through an ammeter with the source grounded. Then slowly increase the voltage of the gate. At the transistor's threshold voltage (as stated in the data sheet) the transistor will start to conduct current.
bountyhunter
Joined Sep 7, 2009
2,512
Thank you ..
You must understand about using power FETs as switching devices: they have a lot of gate capacitance. To get them to switch quickly, which is ESSENTIAL in any switching converter, you must drive them from a low impedance driver which can really crank current. You are driving through a 1k resistor.
We did use the 3524 chips a lot in our power converters (back in the 80's, that was the best available) but we always built discrete drivers to crank the FETs or bipolar power transistors. Driving off the 3524 didn't work well.
charanbandi
Joined May 17, 2012
18
what should i do? to improve the switching charcteristics of mosfets?/?
what are low impedence drivers????
I couldnt understand??
charanbandi
Joined May 17, 2012
18
now the problem with ic 3524 11th pin is giving 7.5v as gate to source voltage but 14th pin giving only 1.8v as Vgs.mosfet is conducting from 3.76v..what should i do?if i change the value of pulling resistors what will happen??
praondevou
Joined Jul 9, 2011
2,942
Where do you measure this voltage? At pin 11 and 14 or at the gate terminals?
Verify the resistor values 1k, 22k.
Disconnect the mosfet gates (and short the gate with the source terminal) and test again.
How did you measure the pin 11, pin 14 voltage ( oscilloscope, I hope) ?
What is connected to pin 1?
charanbandi
Joined May 17, 2012
18
i have measured the voltage at gate terminals only
yes! with oscilloscope only.what if i measured with multimeter??(I mean is there any difference??other than it will measure the rms voltage??)
pin1 is unconnected first and then i have shorted to pin9 ,same result i m getting...!!
I dont understand disconnect the mosfet gates we should measure the voltage across gate pin and source only na!If we shorted them we.ll get 0 Vgs!!!??/
praondevou
Joined Jul 9, 2011
2,942
Did you check the resistor values? Are they really 1k and 22k ? (btw 22k is kind of to high as was mentioned earlier - depending on switching frequency and load current this will cause excessive heating of the MOSFET)
I meant: Disconnect the MOSFET gates from the resistors and short them directly to their source terminal. Then measure the output voltage at pin 11 and 14 with a scope. Are they equal in pulse width and voltage level?
charanbandi
Joined May 17, 2012
18
thanks!The problem got fixed now.I have changed the ic,now i m getting 8.2volts at 14th pin and 5.45v at 11th pin with feedback unconnected i.e pin1 left unconnected..
If i have given the 12volts battery supply to center tapped transformer,I am getting Id as 0.85amps and i have used 25ohm rheostat in series with drain but I couldnt get any output..I have used 10watt bulb connected across the output.what else i need to take care of???
I havent used any filter across the output
charanbandi
Joined May 17, 2012
18
what if the voltage and pulse levels are not equal at both pins??
I have used 25ohm rheostat to make Id equal in both mosfets.
