mosfet driver substitute
Discussion in 'The Projects Forum' started by brad20, Dec 26, 2013.
  1. brad20
    Apr 7, 2013
    12
    Original ic is a 34152 will a 34151 be a good substitute? What parts are needed to build a mosfet driver test circuit?
  2. shortbus
    Sep 30, 2009
    4,098
    1,697
    The 34151 will only work if you want the outputs inverted.
    The 34152 has non-inverting inputs.
    The 34151 has inverting inputs.
    Other than that they look the same.
    A resistor of the proper value and an LED would work for a low side driver tester. But you would need to figure the resistor to suit the voltage and LED you are using.
  3. brad20
    Apr 7, 2013
    12
    A resistor of the proper value and an LED would work for a low side driver tester. But you would need to figure the resistor to suit the voltage and LED you are using. How do you determine this the data sheet for a 33152p shows 6.1-18v current peak 1.5 delay 55ns non inverting
