MOSFET driver simulates but does not work in real life
Discussion in 'General Electronics Chat' started by electrophile, Feb 2, 2016.
  1. electrophile
    Aug 30, 2013
    100
    Attached here is a schematic for a n-mosfet driver (along with the LTSpice schematic). To simulate the load I have an LED with a resistor. The 4N25 opto coupler is controlled through an Arduino (V3 in the schematic). Now this simulates just fine in LTSpice but when I assembled everything on my breadboard it doesn't work. The LED stays on through out. The Arduino code just switches on and off a particular pin at intervals of 2 seconds. Any ideas?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Haven't you by accident swapped the drain pin with the source pine ?
  3. dl324
    Distinguished Member
    Mar 30, 2015
    3,375
    651
    Are you sure you have the MOSFET connected correctly? Measure the voltage on the drain when the LED should be off. If it's 0.7V, you have the S/D reversed.
  4. #12
    Nov 30, 2010
    16,657
    7,300
    I agree. Your schematic is good. It must be an assembly problem.
  5. Bordodynov
    May 20, 2015
    669
    194
    I had a similar problem when soldering confused sometimes collector and emitter of the optocoupler (PCB solder wires to the connector).
  6. electrophile
    Aug 30, 2013
    100
    Thanks folks! I had switched the D and S. Also some of the wiring from the Arduino was bad and once I switched them out and set the MOSFET right, everything worked as expected.
