Hi guys, i have a couple of questions.
But first, what i understood until now about drivers.
What is to be understood ? That a mosfet driver will send a higher voltage pulse(?) to charge the parasitic gate capacitor quicker so the mosfet will turn on in a shorter time, in consequence minimizing switching losses.
I'm pretty sure that's correct.
Now the questions.
1. What is high-side/low-side ? High side is on the positive lead of the load, and low side on the negative one ?
2. How do i interpret datasheet info ? What do all the voltages mean ?
3. How exactly do they work ? Do they first send a higher voltage pulse, cut it off when gate reached desired voltage, and immediately connect a continuous stable voltage source ?
4. Do they work for both turn on and turn off ?
Thank you very much in advance.
Now the questions.
