MOSFET driver circuit, when is 5V too low?
Discussion in 'General Electronics Chat' started by Nicholas, Jan 21, 2016.
  1. Nicholas
    Thread Starter AAC Fanatic!
    Mar 24, 2005
    121
    Hi guys
    Yet another question. I hope you can answer this. The MOSFET is an IRL540.
    I was given the good advice, on this forum, to insert a diode on the mosfet gat, to protect the microprocessor should the
    MOSFET give in or something, and direct 30V back through the gate.
    I have made one of my famous drawings(see below). When the diode and the 10K resistor is in place, my 5V goes to
    4.48V. Will this ensure complete saturation of a logic level MOSFET?
    On a less-important note; if I want to connect an LED + resistor from 5V to gnd (before the diode etc) then my current draw
    goes from nothing, to 10-20mA...on a pin that has a maximum of 30mA. Will this not affect saturation of the MOSFET?
    Thanks for your time!
    Nick
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    Modern LED's will have a good brightness if the LED current is >1mA. So increase your led resistor value and Iled around 5mA or lower.
    As for the MOSFET we need to know what is the load ?
  3. Nicholas
    Mar 24, 2005
    121
    Hi, thanks for your answer!!
    The load will be 36-40V
    Thanks,
    Nick
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    And the load current is??
  5. Nicholas
    Mar 24, 2005
    121
    I would think about 5 amps!
  6. mcgyvr
    Oct 15, 2009
    4,793
    976
  7. Nicholas
    Mar 24, 2005
    121
  8. crutschow
    Mar 14, 2008
    13,521
    3,388
    Don't use "typical curves" for a design. They don't indicate worst case characteristics.
    However the data sheet does shows that, for a Vgs of 4v, the ON resistance is a maximum of 0.11Ω with a drain current of 14A, so you are fine at 5A.
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    The power dissipation in the MOSFET is around Ptot = Id^2*Rds(on) = 5A*5A *2*0.077Ω = 3.85 watts. So, the small heatsink will be needed.
  10. crutschow
    Mar 14, 2008
    13,521
    3,388
    It's only half that value at 1.92W.
    You multiplied by the "2" which is used in that formula as the "squared" indicator.
    But even for that dissipation you should use a small heatsink.
  11. Jony130
    Feb 17, 2009
    3,993
    1,116
    This "2" in the formula I use because, as you know the Rds(on) resistance will rise with junction temperature and this "2" includes this effects (more or less).
    http://www.vishay.com/docs/91300/91300.pdf (Fig 4)
  12. crutschow
    Mar 14, 2008
    13,521
    3,388
    Okay. You just threw that fudge factor of 2 in there with no explanation so I didn't know.
    But that's reasonably conservative since, according to the data sheet, the ON resistance doubling occurs at a junction temperature of about 140°C and you likely don't want to operate much above that junction temperature for good reliability.
