thanks but i mean to say transistor based circuit. like a current mirror circuit.Basically, insert a low value series resistor. Measure the voltage across this resistor. Use ohm's law. Amplify this voltage using a transistor circuit.
Choose a resistor that gives about 0.5V drop at the maximum expected current. Calculate the power dissipated in the resistor at full current. Use a resistor that can handle this power.
The problem with this arrangement is that there is no isolation between MOSFET circuit and the measuring circuit.
Hall-effect current transformers are getting cheaper. Google.
