MOSFET current flow
Discussion in 'General Electronics Chat' started by iulian28ti, Jan 22, 2010.
  1. iulian28ti
    Dec 4, 2009
    42
    This may look like a silly question....
    Does a MOSFET allow bidirectional flow of current ?
    I'm not referring to the intrinsic diode, but at the drain-source junction.
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    A Mosfet variably adjusts its current in one direction. It has a built-in diode that conducts when the drain-source voltage is backwards.
  3. eblc1388
    Nov 28, 2008
    1,542
    102
    Yes, of course. Provided that it is turned fully ON by applying sufficient voltage to the gate.
    Yes, I know.
    The intrinsic diode will allow current flow in one direction even if the MOSFET is NOT turned ON. However, then it has a standard diode drop of about 0.6V. If the MOSFET is turned ON by applying gate voltage at this moment, the 0.6V drop between source and drain will be reduced further, depending on Rds.
  4. iulian28ti
    Dec 4, 2009
    42
    Well... that explains active rectification.
    Thank you :)
