MOSFET CS Amplifier (VTC)
Discussion in 'Homework Help' started by jegues, Sep 27, 2011.
  1. jegues
    Sep 13, 2010
    735
    43
    See figure attached for the question and the figures given.
    I'm having a little trouble for part a), I know at point A,
    v_{GS} = V_{t} and the transistor is just turning on, and since v_{DS} > 0 we will enter saturation.
    For point B,
    v_{GS} - V_{t} = v_{DS}
    but how do I determine Rd from this? I haven't been told anything about vGS or iD.
    Hopefully once I get the ball rolling on part a), parts b), c) & d) should fall into place.
    Thanks again!
    EDIT:
    a) Vgs = Vds + Vt, Vds = 0.6V
    i_{D} = \frac{1}{2}k_{n}(v_{GS} - V_{t})^{2}
    i_{D} = \frac{V_{DD} - V_{DS}}{R_{D}}
    i_{D} = 1.25mA, \quad R_{D} = 1.6k \Omega
    b)
    v_{DS} = 0.5V \quad \rightarrow \quad v_{GS} = 1V
    v_{DS} = 2.5V \quad \rightarrow \quad v_{GS} = 3V
    I'm stuck on part c) now.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    In the first place tell me why you want to find Rd ??
    Rd is given and its equal to Rd = 24kΩ
    As for question a
    The point A is equal to
    V_{ds} = V_{t}
    And point B
    V_{ds} = V_{gs} - V_{t}
    And we also know that:
    V_{ds} = I_{d} * R_{d}
    And
    I_{D} = \frac{1}{2}K_{n}(V_{GS} - V_{T})^{2}
    So you need to solve this equation
    V_{dd} - (I_{d} * R_{d}) = V_{gs} - V_{t} = V_{dd} - \frac{1}{2}K_{n}(V_{GS} - V_{T})^{2}*Rd = (V_{gs} - V_{t})
  3. jegues
    Sep 13, 2010
    735
    43
    Sorry I had posted the wrong question by mistake, the correct one is up there now.
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    I also made the mistake
  5. jegues
    Sep 13, 2010
    735
    43
    It's okay, the correct question is up there now so hopefully things are more clear.
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    As for C
    Simply find Id for Vgs = Vdd next find Vd
    rds = Vd/Id
  7. Jony130
    Feb 17, 2009
    3,993
    1,116
    And can you tell me.
    How can you get Vgs --> 3V for Vds = 2.5V for Vdd = 2.5V ?
  8. jegues
    Sep 13, 2010
    735
    43
    I must have done that incorrectly.
    How do I get the value of Vgs for Vds = 2.5V
    Is part a) okay?
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    The part a) looks okay except the last part Vgs=3V for Vds = 2.5V.
    To get 2.5V as a Vds the drain currant must be equal to zero.
    Then there will be no voltage drop across Rd resistor and Vds = Vdd.
  10. jegues
    Sep 13, 2010
    735
    43
    So as a result, Vgs = Vt = 0.5V, correct?
  11. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes, for Vgs = Vt----> Id=0A
    By the way what "VTC" means ?
  12. jegues
    Sep 13, 2010
    735
    43
    For part C),
    I solved the 2 equations for id for Vds and found that Vds = 0.077V, id = 1.51mA and rd = 50.85 ohms.
    Is this correct?
  13. jegues
    Sep 13, 2010
    735
    43
    Voltage Transfer Characteristic
  14. jegues
    Sep 13, 2010
    735
    43
    Here's my work up to Part C), I'm unsure if the Vds->Id->rd I got for part C) is correct or not.
  15. Jony130
    Feb 17, 2009
    3,993
    1,116
    Can you telly me what value for Kn you use in your calculations?
  16. jegues
    Sep 13, 2010
    735
    43
    k_{n} = k_{n}^{'}(\frac{W}{L})
    Where the values of kn' and W/L are given in my attempt.
  17. Jony130
    Feb 17, 2009
    3,993
    1,116
    So Kn is 10m right ?
