MOSFET Control
Discussion in 'General Electronics Chat' started by Tim Saunders, Jun 17, 2009.
  1. Tim Saunders
    Apr 28, 2009
    10
    Hi
    I'm building a circuit like so:
    8-bit DAC > OP-AMP(as a buffer) > MOSFET > 555 circuit > Servo
    I use the MOSFET to control current which in turn controls timing.
    Since the MOSFET is only useful from 4V (threshold voltage) to 5V and the DAC puts out 0V to 5V, I lose 204 degrees of accuracy. How could I solve this problem?
    -The DAC is home made so I could modify it, it's a R-2R setup.
    -It's a power MOSFET, is it possible to get low threshold voltage FET?
    It seems like there should be a simple solution, but I just can't think of it!
    I'm interested in learning so if this whole thing seems like a stupid approach (maybe a MOSFET is not the right tool) please tell me.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you post the schematic of the circuit? It's really hard to guess what is going on.
  3. Tim Saunders
    Apr 28, 2009
    10
    All I really need to know is how I can change a 0V-5V signal to a 4V-5V signal. I'm using the MOSFET like a variable resistor. Let's see how my drawing skills are:
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Tim,
    Create/save your image in .PNG format. .jpg format is too lossy. MS Paint can save in .png.
    Make sure the image is under 100k before uploading it.
  5. Tim Saunders
    Apr 28, 2009
    10
    Sorry it looked fine on my screen. Here is the PNG image:
    Is it better? I could draw it in LTspice if that's better
  6. AdrianN
    Apr 27, 2009
    97
    Add these two resistors to your OpAmp.
  7. AdrianN
    Apr 27, 2009
    97
  8. Tim Saunders
    Apr 28, 2009
    10
    Geezz, Of coarse! Lol. I don't know why I couldn't think of that!
    Hey thanks alot eh, I really appreciate it.
