I have made an N-Channel MOSFET(IRFZ44) chopper to control a 12V permanent magnet motor that is taking about 8A when loaded . The microcontroller(89s52) generates the PWM signal. The PWM voltage has been applied across the gate source terminals of the MOSFET. A maximum volatge of 6V is being applied to the gate-source terminal. What I want to know is that, whether should I connect the microcontroller output to the gate of the MOSFET using a resistance? Or is it safe to connect directly? Or will I need a MOSFET driver? I could not find anything in the datasheet of IRFZ44 about maximum gate current. If I need to connect the resistance...what should be its value? I have attached a schematic of my circuit. Please help!!!
