Mosfet Analysis
Discussion in 'Homework Help' started by dalam, Sep 8, 2014.
  1. dalam
    Aug 9, 2014
    58
    6
    How should I analyse this circuit?
    I did it assuming PNP MOSFET on and NPN off and then change the assumption. It became too complex. Can I solve it simply be looking at options available?
  2. crutschow
    Mar 14, 2008
    13,515
    3,386
    NPN and PNP refers to the polarity of BJTs. MOSFETs are defined as N-channel or P-channel.
    The circuit is in the linear region when both MOSFETs are conducting at the same time. So under what input voltage conditions is that true? Do you know what Vtp and Vtn means?
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
  4. dalam
    Aug 9, 2014
    58
    6
    Yes, I know what Vtp/Vtn means. It specifies the minimum |Vgs| needed to turn the mosfet on. This is required to create the channel.
    Which region should I choose ? Linear or sturation?
  5. dalam
    Aug 9, 2014
    58
    6
  6. #12
    Nov 30, 2010
    16,705
    7,358
    Because A only defines one end of the region in question. Right, Jony?
  7. Jony130
    Feb 17, 2009
    3,993
    1,116
    Good question. But forget about that, I wrongly understood the question. They ask only about M1 transistor. And ask about the linear region (triode region). So in this case I choose A as a right answer.
  8. crutschow
    Mar 14, 2008
    13,515
    3,386
    Answer A might be correct if it was >1.875V but it says <1.875V.
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    M1 is a P channel so for Vin<1.875V M1 will be in triode/linear region.
  10. crutschow
    Mar 14, 2008
    13,515
    3,386
    Egg on my face. :oops: I was thinking of M2.
  11. dalam
    Aug 9, 2014
    58
    6
    Jony, I understand that A is correct answer among these. But what does the value of 1.875V signifies here? Why it is a boundary? Or is it to be solved by just looking at options?
  12. Jony130
    Feb 17, 2009
    3,993
    1,116
    Well for Vin>1.875 the M1 transistor leaves the linear region and enters the saturation region.
    So, M1 is in linear region and M2 is in saturation.
    ID1 = ID2
    Id1 = Kp*(Vgs - Vtp)*Vds - Vds^2/2
    Id1 = 0.5*Kn*(Vgs - Vtn)^2
    Then
    (Vin - Vdd - Vtp)*(Vout-Vdd) - (Vout - Vdd)^2/2 = 0.5*(Vin - Vtn)^2
    And M1 leaves the linear region when Vds = (Vgs - Vtp) hence Vout - Vdd = Vin - Vdd - Vtp
    then
    Vout = Vin - Vt
    And after we solve this for Vin I get 1.8333V
    http://www.wolframalpha.com/input/?i=(X+-+5+-+(-1))+*+(X+-+1+-+5)+-+(X+-+1+-+5)^2/2+=+(X+-+1)^2/2
    But I made a error so this solution is not true.
    http://oldeee.see.ed.ac.uk/private/ee3/med/rc/week5MOSFET.pdf
    http://www.prenhall.com/howe3/microelectronics/pdf_folder/lectures/tth/lecture11.fm5.pdf
    http://nptel.ac.in/courses/117101058/downloads/Lec-15.pdf
    dalam likes this.
  13. dalam
    Aug 9, 2014
    58
    6
    Thanks a lot Jony!! You have helped me a lot here.
    I guess in case of PMOS the Vgs,Vds should be Vsg and Vsd respectively.
