MOS as a switch
PG1995
Joined Apr 15, 2011
832
Hi :)
In one of the queries about the course Logic Design and Switching Theory I was told that the part "Switching Theory" refers to the fact MOS used as a switching device which turns on/off by sensing the input voltage or whatever. MOS stands for 'Metal Oxide Semiconductor". Is this "MOS" a transistor, diode, or what? I think it's a transistor because a transistor can be used as a switch. What is so special about the "Metal Oxide" prefix? Do we use only those semiconductors to switch on/off the circuits which have been made from metal oxide? Please help me with it. Thank you.
Regards
PG
colinb
Joined Jun 15, 2011
351
You must be referring to a MOSFET, a type of field effect transistor (FET), which itself is a specific type of transistor--other common types being bipolar junction transistor (BJT) and junction gate field-effect transistor (JFET).
A MOSFET's gate is voltage-controlled, as opposed to a BJT where the output current is proportional to the input current (this holds under certain conditions, at least). The first obvious difference between a BJT and MOSFET is that the MOSFET has a very high input impedance, meaning that the MOSFET gate essentially consumes no current at all. On the other hand, a BJT base needs some current flowing to the emitter to turn on the transistor.
colinb
Joined Jun 15, 2011
351
P.S. The term metal oxide refers to the use of a metal oxide as the insulating layer between the gate terminal and the source substrate. See WP: MOSFET for a useful diagram of MOSFET structure. MOSFETs are a common name for insulated-gate field-effect transistor (IGFET), where IGFET also suggests the “insulated” nature of the gate and thus explaining the high impedance of the IGFET/MOSFET gate terminal.
Crispin
Joined Jul 4, 2011
94
A MOSFET's gate is voltage-controlled ... [snip]...MOSFET has a very high input impedance, meaning that the MOSFET gate essentially consumes no current at all.
Why are there dedicated drivers then? If I have a MOSFET which has a threshold voltage (think that is the term?) of 5V, is there any reason I could not drive it from a MCU?
Are drivers used when either the required voltage is higher than you have (3.3?) or is it to "help out" with the gate capacitance?
On the latter point, is that anything to worry about other than when switching very fast as that would load the driver a bit and slow down the switch time.
Hope questions are seen as an addition and not a hi-jack :cool:
colinb
Joined Jun 15, 2011
351
You are right: when you want to switch MOSFETs at a high rate (e.g., for high power PWM control) then you want to drive transitions fast so a MOSFET driver can use a higher voltage and supply the higher transient currents required to charge the gate capacitor.
colinb
Joined Jun 15, 2011
351
I drive some logic-level MOSFETs with PWM for high-power LED control from microcontroller output pins and from 74HC595 outputs, so you don't always need a MOSFET driver, but it really depends on the application.
CraigHB
Joined Aug 12, 2011
127
Depends on gate charge and frequency. For a power MOSFET switching higher currents at higher frequency, a driver may be required. In that situation, you need a low output impedance to source the currents required in overcoming the larger gate capacitance. A micro-controller may not be able to handle it. You could overload the controller or get unsatisfactory switching response. You have to look at what you're trying to do and determine if a driver is required or not.
I try to avoid loading output pins too much on MCUs. I have a pretty low threshold there. If currents are going to get into the milliamps, I usually start looking at different ways to drive stuff. Things like opto-isolators and small signal MOSFETs come in handy for that. I'm pretty quick to use a driver of some kind to drive power MOSFETS at any considerable frequency.
kubeek
Joined Sep 20, 2005
5,795
There is a big reason why it can´t. Threshold voltage is NOT the voltage that makes the transistor fully open. It is usually specified as the voltage that lets 1mA or 250uA flow between D-S, look carefully and you will see some footnotes in your datasheet.
Adjuster
Joined Dec 26, 2010
2,148
For this you would require a "logic level" MOSFET, that is to say a device which has a threshold voltage a good deal less than 5V, and which is specified to be reasonably well turned on by that voltage.
