More Images per post?
Discussion in 'Feedback and Suggestions' started by Wendy, Oct 2, 2009.
  1. Wendy
    Thread Starter Moderator
    Mar 24, 2008
    20,772
    2,540
    I've run into the 5 image limit on the posts for the LED,555s article. I'm wondering if it would be possible to boost this to 8? If not I can work with it, but there is a slight mismatch between the forums (6 images) and the blogs (5 images).
    I'm using this GIF to space the width of the posts to something a little more consistant, basically formatting tols.
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ok Bill, as requested I have raised the blog image limit to 8. Can you test it and make sure you can post up that amount of images. I will keep the forum limit at 6 for the time being as I do not feel it necessary or appropriate to raise that at this time (hence leaving the inconsistency in there!)
    Dave
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Thank you, it shall be done. :)
    Did that, didnt' work. Got this screen.
  4. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Hmm. Can you do me another favour. Could you create a NEW blog entry and try and append 8 images to that. Do you still have a problem? (I would try it but my account has distinctly different permissions to yours).
    Dave
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, but it will take a bit longer, gotta step out and do some errands. Thanks again.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, tried it on a new thread, with similar results. Is it possble that the replies are limited while the first post has expanded privaleges?
  7. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ok, thanks for checking that Bill. I'm not entirely sure, the blog options are quite convoluted and, whereas I am familiar with the intricacies of the forum settings, I am less well versed on the blog settings. I will hopefully get a chance this afternoon to have a look at it in more detail. I will post up because I will probably want you to test it for me.
    Dave
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    No problem. And thank you, even if it can't be done.
    I'm working on a chapter called The LED / Resistor Only Bargraph.
    This sucker could eat image space, because trying to explain it is a bit convoluted. If it is necessary I can merge pictures into one big one, and put Figure designations inside the image.
  9. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Ok, try it now Bill.
    Dave
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Thank you! It works! Now I can be twice as obno... informative!
    7 was the magic number, I can match the 6 posts allowed in the forum, plus one format image.
  11. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    It does include other image-based BB-code such as smilies so a liberal interpretation of the limit is worth trialling.
    Obviously I will monitor this for abuse and may, if necessary, have to take corrective actions which may include downgrading the limit. I will let you know if I do this so we can work on a solution that is amicable for all.
    Dave
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just curious (and I'm not asking for names) is there anyone that uses more images than me? I would bet my stuff is on target as to how it is meant to be used.
    I notice I have megs of space used for attachments in various posts.
  13. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You use it the most, but others do use it quite a bit. See http://forum.allaboutcircuits.com/album.php
    And that is just the recently updated.
    In total, there are nearly 1GB of attachments on the server. That is a pretty big increase on last year.
    Dave
  14. bigcape
    Member
    Sep 18, 2009
    158
    Are you guys okay with my uploads? 1 GIG, are you guys tight for space?
    My FTP host server charges $6.95 a month for 20Gigs
  15. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    We have more than enough space. I am merely making a point of the YoY increase of attachments.
    Dave
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    YoY? Never heard that one. Checked google, didn't find it.
  17. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Year-on-year.
    Dave
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    OK, that was one of the definitions I saw, but I didn't make the connection. Thanks.
  19. bigcape
    Member
    Sep 18, 2009
    158
    you guys crack me up
  20. bigcape
    Member
    Sep 18, 2009
    158
    I gave you your space back.
