More Ic2 programming interfacing DS895450 with an MMA8452Q accelerometer HELP!
Discussion in 'Embedded Systems and Microcontrollers' started by iankellogg, Apr 7, 2012.
  1. iankellogg
    Oct 16, 2009
    I have been working on this chip for a few days and have been running into the same issue. I have 3 chips and all three exhibit this behavior. On the scope you can see that the chip is responding to the bus but it is unable to drive the signal low. On the scope it for whatever reason pulls the signal to 2.5v and I have been unable to figure out why. I know it isn't a problem with the bus itself because i have plenty of other chips working just fine on the same line.
  2. chrisw1990
    Oct 22, 2011
    543
    41
    how do you know its this chip thats pulling it low? i assume 3v3? have you got hardware schematic?
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. chrisw1990
    Oct 22, 2011
    543
    41
    good spot, hadnt noticed!
