Monostable Problem
Discussion in 'Homework Help' started by Malsch, May 30, 2011.
  1. Malsch
    Mar 19, 2011
    23
    I am trying to produce a 1 second pulse with the monostable but for some reason, the output is the inverting of the trigger. The following screenshot explains it all:
    Any help why this is happening to me would be appreciated :)
    Thank you.
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
  3. Kingsparks
    Member
    May 17, 2011
    118
    5
    If you need a positive going pulse from the circuit you can put an inverter on the output from the 555. That will give the same polarity as your trigger pulse. :eek:
