Monostable IC 555 Circuit
Discussion in 'The Projects Forum' started by vick5821, Jan 29, 2012.
  1. vick5821
    Jan 27, 2012
    54
    Hey friends, recently I have built a 555 monostable circuit.It works fine.However, the circuit will lights up if I shake the circuit and off after some period of time.I didnt press the trigger button.
    Anyone knows what happened ?
    The connection I think is ok since it works.
    Thank you
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    Do you have all capacitors in place? Power supply bypass? Is the timer snug in it's socket? Are you triggering it by touching any of the exposed conductors?
    Just some thoughts.
  3. vick5821
    Jan 27, 2012
    54
    Oh yes..I forgot to put the capacitor when took this picture.I will put them in the female header socket..Yes, it will being triggered if I touch the back side of the donut board
  4. sheldons
    Oct 26, 2011
    616
    101
    where is your timing capacitor?post your schematic ?
  5. vick5821
    Jan 27, 2012
    54
    My timing capacitor is connected between the trigger, threshold pin and ground pin..will post the schematic soon :)
