I have a mono source which I need to output to a mono line level output and also to stereo heaphones.
I have looked online for stereo headphone op-amp circuits and they all use 2 opamps (because normally the source would be stereo).
I only have 1 opamp left on my IC and am loathed to break into another, especially when my source is mono.
At the moment I am just splitting the output of the opamp and sending each branch through a 16 ohm resister and 220uF capacitor.
Is this OK? I'm guessing it may not be. I realise you can't just tie the left and right channel of the headphones together, as you would be essentially creating a much smaller load, as both headphones would be in parallel.
Should I adjust my output resister and capacitor values?
Here's the circuit, with the loads shown as resistors.
thanks
Paul
thanks
Paul
