monitoring the status of device which is connected to the mc
Discussion in 'Embedded Systems and Microcontrollers' started by shanthiga, Jan 20, 2010.
  1. shanthiga
    Jan 20, 2010
    5
    pls anybody help,
    i want to monitor the device status through the microcontroller...im trying to design a circuit with using series current to voltage transformer..is it correct or is there any other options to implement?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A resistor can be a current to voltage transformer. What is the device? Are you trying to determine if it is on or off?
  3. shanthiga
    Jan 20, 2010
    5
    yeah. i'm trying to determine whether the load is on or off... mainly for incandensecent light. others which is below 1500W.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    what kind of microcontroller are you using
  5. shanthiga
    Jan 20, 2010
    5
    going to use PIC18F series...........
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Ok can you give some data about the current transformer. Like data sheet and how you are going to implement in your circuit. If this a mains related or high voltage setup (> 50 volt). I think a current transformer is the best thing to use, and it is also safe.
