monitoring and controlling noisy signal
Discussion in 'The Projects Forum' started by mikesolar, Jun 21, 2015.
  1. mikesolar
    Jun 21, 2015
    9
    Hi all, this is my first post (of many, I expect). I am trying to monitor a variable voltage signal from 10-20vdc and this signal will have intermittent spikes of up to 200v. What I am trying to do is find a way to ignore the spikes (they have a purpose so I don't want to get rid of them), and use the 10-20v as a trigger for my device. I am concerned that the 200v spikes will damage any measurement circuits or mess up the readings. Is there a relatively simple way to do this? Sorry if it is a bit of an obtuse question.
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Can you show us the circuit that you currently have for processing this signal?
    A schematic of the source with the spike generation would also be handy.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Can you give some more information on the device to be triggered?
    Bertus
  4. ronv
    Nov 12, 2008
    3,392
    1,447
    Maybe just a bit more information.
    How long do the spikes last?
    Do you just need to know the signal changed from 10 to 20 volts or do you need to know it's level.
    What will make the measurement? Hardware or micro?
  5. mikesolar
    Jun 21, 2015
    9
    It is a battery charger of sorts. I am trying to see what happens when I put a pulse input to a couple different types of batteries. I'm working on an electric truck. I will have to draw up a schematic (which my cad skills will take a bit of time, haha).
    The batteries will, of course, have to start to charge at the lower end and shut off at the higher end. The voltage range is just for testing as the battery pack final voltage is not known yet. There is a lot of range with these motors depending on the motor maker.
  6. mikesolar
    Jun 21, 2015
    9
    The spikes i suspect will be at 1khz
  7. crutschow
    Mar 14, 2008
    13,469
    3,356
    One obvious way to limit the spikes is with a series resistor and a 25V Zener to ground.
  8. mikesolar
    Jun 21, 2015
    9
    I don't want to limit the spikes but I do want to only measure the voltage between the spikes
  9. #12
    Nov 30, 2010
    16,656
    7,296
    Then limit the input to the measuring device. If the measuring device can't survive 200 volts, don't apply them to it. Did somebody tell you that you can't connect a limiter to your meter so it only measures between the spikes???
  10. Alec_t
    Sep 17, 2013
    5,956
    1,131
    Are these two separate requirements?
  11. mikesolar
    Jun 21, 2015
    9
    I wont' be using a multimeter to measure it because it has to be somewhat automatic. It needs to "see" the 10v (for example) on the battery, turn on the charge circuit and let it charge till it hits X volts. But how to weed out the effect of the spikes and still let the charger read properly?
  12. mikesolar
    Jun 21, 2015
    9
    Nope, no one said that it cannot be done. I guess I would need to do parallel measurements, one with the spikes removed to measure and control the circuit.
  13. #12
    Nov 30, 2010
    16,656
    7,296
    Many ways to skin that cat, from some complicated microprocessor that knows about timing to a simple low pass filter that essentially ignores anything that is .001 second long.
    How much time between these millisecond long pulses? Several seconds?
  14. mikesolar
    Jun 21, 2015
    9
    Thats a good question. Time between pulses is not set yet. I'm moving houses and my scope is packed away in a box for the next month along with much of my other electronic stuff. Stupid me to do that, haha. To be sure I would like to get it out and see what the waveform looks like but, in principle, putting a VM across the signal and grounding out the pulse would allow me to monitor the actual battery voltage, I guess, then create something that can recognize the value and start/stop the charging. What would be wrong with this approach?
  15. #12
    Nov 30, 2010
    16,656
    7,296
    So half baked. So lack of information. So, no answers.
  16. mikesolar
    Jun 21, 2015
    9
    I'll report back when I have more info
  17. ronv
    Nov 12, 2008
    3,392
    1,447
    Unless you are hitting the battery with really high current it will limit the voltage. So I would just run the battery thru a resistor with a zener clamp in case there is some inductance. Then just integrate it to get average battery voltage.
    #12 likes this.
  18. #12
    Nov 30, 2010
    16,656
    7,296
    integrate: sometimes means the same thing as, "low pass filter"
    A resistor and a capacitor might be all you need. $1 to $2
    Now, spill the beans. We're tired of trying to imagine exactly what you are talking about.
  19. crutschow
    Mar 14, 2008
    13,469
    3,356
    I'm talking about clamping the spikes at the input to the measurement circuit so they aren't measured.
    That won't affect the spikes in the circuit that's generating them.
  20. mikesolar
    Jun 21, 2015
    9
    You guys have given me lots to think about. The ultimate goal is to be able to stop the charging process at the right time with an accurate measurement. The best way to know if a battery is fully charged is by taking a specific gravity measurement of the electrolyte but there is no cheap automated way to do this so this is the next best thing. Sometimes a battery voltage measurement is not accurate until it has been allowed to settle which can't be done when charging so I am starting to think of a correction factor.
    Now to make the proper circuit to measure voltage without the spikes. More investigation. Oddly enough, I went to DeVry 30+ years ago, got a technologist ticket and never worked it the industry so forgot much of what I learned. Time to get some of it back.
