Monitor Issue: Philips 104E 14” monitor
Discussion in 'General Electronics Chat' started by ranatungawk, Nov 24, 2009.
  1. ranatungawk
    Thread Starter Senior Member
    Oct 30, 2008
    147
    I’m using a Philips 104E 14” monitor. When I use it, it goes off suddenly (no even standby LED) and then it couldn’t be turn on. When it’s working I can’t control the horizontal width even with the control battens. I did following troubleshooting steps :
    1. All dry-joints were soldered.
    2.horizontal transistor TIP122 and H-Out transistor were replaced with new ones but problem still remain same.
    3 .then in order to check the voltage at H-out transistor, 230V bulb was connected to the points where E and C of the H-out transistor were connected. (and H-out was removed from the board )When I turn on the monitor I found the bulb is blinking (this is abnormal and fixed voltage should come to the h-out Tr, I think.)
    ******After removing the H-out transistor amber color LED came up.
    Can this be a Fly-back issue? Please guide how to troubleshoot this
    Kushan
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Found this link related to your problem: http://www.fixya.com/support/t355616-philips_104e_width_uncontrollable
    Electrolytic caps don't age very gracefully. Some Asian manufacturers were using an electrolyte concentration that was much too strong; that leads to early cap failures.
    Leaking caps can easily cause other components to get burned up due to the high currents involved; they may be quite a distance away from the leaking cap(s).
    It sounds like you have a couple of unrelated problems going on. It's going to be hard to troubleshoot without a schematic.
