momentary to latching
Discussion in 'The Projects Forum' started by hemi 426, Apr 8, 2013.
Thread Status:
Not open for further replies.
  1. hemi 426
    Apr 8, 2013
    does anybody have a simple diagram that shows how to use a momentary switch to turn on a circuit then hit the momentary switch again to turn the circuit off.
  2. Biff383
    Member
    Jun 6, 2012
    49
    19
    Here you go.
  3. trader007
    Feb 27, 2010
    222
    19
  4. #12
    Nov 30, 2010
    16,671
    7,318
    Looks good to me.
  5. wirednuts
    Nov 13, 2011
    20
    ok. if anyone else wants to make this, i rounded up the cheapest parts i could find on digikey, that also had good thermal ratings.
    BS170_D75ZCT-NDMOSFET N-CH 60V 500MA TO-92
    NTD2955-1GOS-NDMOSFET P-CH 60V 12A IPAK
    CF14JT100KCT-NDRES 100K OHM 1/4W 5% CARBON FILM
    S1MQCT-NDRES 1M OHM 1/4W 5% CF MINI
    399-4491-1-NDCAP CER 0.1UF 50V 10% AXIAL
    they are all through hole components, so it should be easy to build. cost is about $25 shipped to make 24 of these :D you don't save much by ordering just a couple... Should be stable from -50C to 150C, and be able to switch up to 50w!
  6. declancole
    Jan 27, 2015
    Has anyone built this circuit?
    Did it function as intended?
Thread Status:
