I need to make a switch that takes a momentary signal(I would have to scope the signal to get details) 12 volts, 200milliamps and output a constant 12 volt 2amp signal. I would also like to have the same momentary signal turn off the constant signal.
I have accomplished this with 4 relays that latch and unlatch. That setup was unreliable. I am thinking the way to go is to use a logic module and drivers to accomplish this.
Any thoughts? I have never built a circuit board before, I'm thinking this would be a simple project to start with. Thanks for any help in advance
