Momentary switch to latched on/off toggle
Discussion in 'The Projects Forum' started by andyman, Jan 19, 2009.
  1. andyman
    Jan 19, 2009
    7
    I'm totally new to this forum and somewhat new to electronics. I'm looking for a circuit to convert a momentary switch to a toggled, latched, on/off switch.
  2. mik3
    Feb 4, 2008
    4,846
    63
    You can use a JK flip flop with its J and K inputs at logic 1. A JK with its inputs at logic 1 is also named as a T flip flop. With the JK in this arrangement the output Q will toggle between 0 and 1 (logic) each time you apply a clock pulse (press the momentary switch). Have a look here:
    http://www.play-hookey.com/digital/jk_nand_flip-flop.html
    Press on the blue inputs to make simulation.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    AudioGuru has published a 2 transistor (3?) several times that looks fairly simple. If I can find it I'll attach the link.
    Found one (there were several)...
    This one was here.
