Momentary SP Switch
Discussion in 'General Electronics Chat' started by SteveYTI, Oct 31, 2004.
Thread Status:
Not open for further replies.
  1. SteveYTI
    Feb 9, 2004
    23
    I have a pushbutton momentary SP switch. I want to be able to latch a relay on with this switch and then turn it off as well. I have been racking my brain for a while now and am convinced that if I use a timer I will be able to use 2 relays and be able to break the circuit after latching it on. If there is a better way I would love input.
    Thanks!
  2. cyberhehe
    Oct 6, 2004
    61
    I want to know how you want it to be implemented: a pure electrical configuration consisting only of relays and your push button or a combination of electronics circuit (with discrete or logic components) implementation together with a relay?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you can stand to add a D flip-flop, you can toggle it with the switch and use Q or not_Q for the on/off level.
  4. nikhilsonar29
    Member
    Sep 26, 2014
    68
    i have already done with this project
    i used 555 timer ic to do so
    and the circuit is doing well
  5. MrChips
    Oct 2, 2009
    12,642
    3,457
    Don't dig up threads that are 10 years old.
Thread Status:
