All:
I have a project I'd like to tackle. I call it "motorcycle safety".
In my previous house, I took an LM317 and adjusted resistor values to engage a "stuck on" garage door opener remote. This remote ran at 6v, and never gave me any issues. The input for the circuit ties into my high beam output directly from the headlamp assembly in the motorcycle.
My new garage door opener takes 3v. However, since I'm further away from the city I can see using the high beams for longer periods of time. I could take the shortcut route and just adapt my lm317 solution to provide constant on to the remote, but I think having a momentary on switch circuit might be a better idea. I'm thinking anywere from 1-5 seconds, and then off for the rest of the duration of the input voltage. I just don't like the idea of the remote being on constantly while I am away from the house with high beams on.
I've seen several different schematics here that I can take and modify - so if it were up to you, how would you do it? I have 2 available 12v inputs - a constant on source and the high beam source, and the output can be either a switch of sorts (to "press" the garage door opener) or I might just feed the lm317 directly so I don't have to worry about button cell battery life.
Let me know what you think!
